Closed INO Hershey's Kisses Template...searched, found, must be doing something wrong?!
Discussion in 'Wrapcandy Elite Main Sharing Board' started by mjokeefe97, May 25, 2011.
Thread Status:
Not open for further replies.
  1. mjokeefe97 Registered Member
    Ok...so I have searched and searched and searched for the hershey's kisses Template and read just about EVERYTHING there is to read about hersey's kisses. I even found a CWR template, as well as a jpeg with some suggestions about using a hole punch for the kisses, but I don't really want to take all that time to punch ALL of those out!
    So, ordered from onlinelabels.com (which was suggested on one of the topics). I ordered the 3/4" blank white stickers with 108 on a page, but my issue is, even when I use the template, CWR or JPEG to print out 108, only one prints!
    What in the world am I doing wrong? :(
    Also, does anyone else use the stickers with 108 on a sheet? If so, any information/help you can give me would be GREATLY appreciated! Thanks!
    [size=14pt]help, help, help...confused, confused, confused!
    Michele
  2. demilleraly Elite Plus
    I often have this problem. What I do to rectify is select print preview. I look to see if there's only one. Then I cancel and select print (not print preview). It will then print all kisses. Hope this helps.
  3. OP
    mjokeefe97
    Thank you Denise for your quick reply!
    Now, I decided to use the CWR template. I added my image, changed the properties all to 0 (which was suggested on here), but now when I click 'print preview' it is wanting to print 140 on one page...(SIGH)
    What do you set your properties to when you go to print? Also, do you use the 8.5 X 11 sheets of 108 stickers for your kisses?
  4. maxluv Staff Elite Plus
    Have you tried using the template that you get from Online Labels? You get a free 30 days or something when you buy from them to use there own program, that at this moment i cannot think of what it is called. Maestro is what it is called.
  5. There is a template/cwr file that has the 108 circles for the kisses. Look in the Hershey Kisses sub forum...when on the first page, scroll down. I'll see if I can find it...
  6. Aack! I can't find it. Maybe someone else has it or knows where it's at...sorry:(
    I have it in a cwr but it's 7.3 Pro
  7. helperlearner Staff Member LIFETIME MEMBER 2017 Reunion Elite Registered Member
    Reply #2 and #4
    bhttp://www.wrapcandy.com/forum/index.php/topic,56383.msg743203.html#msg743203
    This post has several links provided by P
    http://www.wrapcandy.com/forum/index.php/topic,89638.msg1216744.html#msg1216744
  8. Thank you Ann!!!
  9. OP
    mjokeefe97
    Thank all of you sooooooo much! I was started to go BATTY!! :p THANK YOU, THANK YOU, THANK YOU!! I will give this template a try!
  10. mariefyfe Lifetime Elite Platinum Elite Plus 2017 Reunion
    I actually did this the other night - I too had labels from ONline Labels -- I printed them out in Microsoft Word -- I had to put in a custom label size using their dimensions noted on their website and it worked perfectly. I had a little trouble inserting pictures, but once I got that fixed I had no trouble.
    You would go into Label tab and pick custom and then put in all the dimensions and a little square is created -- when you pick open document you get a full page of squares .75X.75
    Like I said I had a little trouble inserting the pictures to get them centered, that was my biggest challenge. I would print out the page and old it up to the light with the lable sheet on top of it just to see how it matched up. I was using different graphics for each square (well 6 different graphics) .... hope this helps some people who like to do things in Word .
Similar Threads: Hershey's Kisses
Wrapcandy Elite Main Sharing Board Hershey's Kisses 108 labels template needed Oct 19, 2011
Wrapcandy Elite Main Sharing Board Hershey's Kisses Avery 5408 Feb 12, 2010
Wrapcandy Elite Main Sharing Board Hershey's Candy Cane Kisses Oct 20, 2008
Wrapcandy Elite Main Sharing Board Hershey's Kisses Nov 12, 2007
Wrapcandy Elite Main Sharing Board .75 labels for Hershey's Kisses for Sale! Feb 24, 2006
Thread Status:
  • angelischarmed
  • starcent
  • deserty5
  • trussme
  • niecey2k4
  • favorwraps
  • audrey220
  • brandy
  • hkmchan
  • chriskari
  • trinity
  • tdgiftsol
  • tlc04076
  • pepmyka
  • smcqueen
  • dizzy
  • oyuki
  • bjs1952
  • rocros
  • guidryliz
  • boatmanbears
  • jtaylortx32
  • bbygrl1970
